Author Topic: help, led doesn't turn on, sunking  (Read 1593 times)
Ang3lus
  • Stompbox Star
« on: January 25, 2011, 09:58:10 AM »
help, my led doesn't turn on on my sunking build, i'm using a 3pdt switch with the middle columnn not connected at all, tried switching between the leds wires but still won't turn on.
pedal works fine, all knobs and buffer bypass also.
p.s using a buffered bypass, not true bypass :)
B_of_H
  • Solder Ninja
  • electronics moran
Re: help, led doesn't turn on, sunking
« Reply #1 on: January 25, 2011, 10:18:32 AM »
did you wire the LED backwards (+ for -)?
can you physically ground the LED and have it light up but when you attach it to the switch it doesn't work?  got pics?
  • Administrator
  • Brian
    • madbeanpedals
« Reply #2 on: January 25, 2011, 10:34:25 AM »
Seconded. LED must be wired backwards.
  • Global Moderator
  • Jacob - SK, Canada
    • JMK PCBs
« Reply #3 on: January 25, 2011, 11:48:47 AM »
Another option is your LED is no good. I've had that problem lately - three bum LED's.
Ang3lus
  • Stompbox Star
« Reply #4 on: January 25, 2011, 12:56:45 PM »
will the led work directly to a 9v source ?
just wire the + and - ?
cause i've reversed the wires and it still won't light up
  • Global Moderator
    • JMK PCBs
« Reply #5 on: January 25, 2011, 01:00:48 PM »
No, you need to have a current limiting resistor in series with the LED. If you hook an LED straight to power and ground, the LED will blow.
However, on the sunking, the LED spot on the board includes current limiting resistor - did you use the pads on the board?
jacob
Ang3lus
  • Stompbox Star
« Reply #6 on: January 25, 2011, 01:09:43 PM »
yes, i did use the pads on the board, thought i hooked them right, no budge, tried reversing, no budge again.
  • Administrator
  • Brian
    • madbeanpedals
« Reply #7 on: January 25, 2011, 01:17:22 PM »
Hmm. Can we see a pic of how you have it wired? I mean, the board and 3pdt?
Ang3lus
  • Stompbox Star
« Reply #8 on: January 26, 2011, 12:41:05 AM »
yeah, i'll try getting a screenshot today
Ang3lus
  • Stompbox Star
« Reply #9 on: January 26, 2011, 09:53:50 AM »
wired it the right way the first time, was just a cold solder joint
hate when that happens
pedal works perfectly, just some tiding up and i'll post some pics :)
