Parts templates for inkscape
Started by Gledison, August 13, 2013, 03:44:42 PM
Gledison
Hey guys.
Has anyone templates of pots and lets, etc for inkscape? For sharing?
Thanks a lot
ThePastRecedes
I build stuff for myself, sometimes I do 1 offs, I label them as HornBlende Audio.
Gledison
Quote from: ThePastRecedes on August 13, 2013, 05:07:51 PM
http://www.aronnelson.com/gallery/main.php?g2_view=core.DownloadItem&g2_itemId=47294
This is great, thanks a lot!
any trick in how to insert on inkscape? or I have to do a copy paste, and correct the sizes as described on the template?
cheers
ThePastRecedes
I use adobe illustrator but I just open the file using that programme.
Gledison
in illustrator do you have to resize the pics? or you cut one by one, like the knobs for ex?
cheers
ThePastRecedes
The dimensions are correct. I just copy and paste of the main doc. If I have the same style knob in a different size I just resize the knob to the desired size.
Gledison
Do you copy from the pdf original file or do u copy after opening the pdf on ilustrator? I cannot select every part i dividually! It opens the whole pdf as one big pucture! Sorry im not used to ilustrator.
Thanks for your help mate!
rullywowr
In Inkscape, you simply double click on the part you want (knob, enclosure) etc....and 90% of the time it will select the part you want.  You can drag/drop or copy/paste it after that.  If you are having trouble selecting the entire part you can hold SHIFT or CNTL in addition to the click and it should work OK.  Sometimes its a bit weird but usually works just fine.
Gledison
insomniac2295
Woah, my mind was just blown by that PDF! I've been making my own measurements and doing everything the hard way in sketchup! This is awesome
Gledison
Yessss! Thanks the Past Recedes! Its very helpfull!!!
