Sharkfin opamp substitution
Started by aballen, September 12, 2013, 07:13:38 PM
aballen
Is it safe to replace the lm741 opamps with lm741 op amps?
das234
hammerheadmusicman
RobA
Haberdasher
haha he probably meant ua741 or njm741, both of which should work afaik.
fwiw, i read once that OP07 was made to replace/upgrade the 741, and tayda has them cheap.  I'm going to try them in my sharkfin pcb if i ever locate a 2mb pot.
FABBED PCB's FOR SALE:
Now carrying Matched JFETS
billstein
Definitely go with the lm741 op amp. Whatever you do, don't use the lm741 opamp!
Quote from: Haberdasher on September 13, 2013, 10:56:23 AM
Small bear gots the 2mb pots. Someone should head up a group buy...
Haberdasher
Quote from: jimilee on September 13, 2013, 01:21:58 PM
Yeah, even a small group buy cooperative would be cool in this case, because that's about the only thing I'd need from smallbear atm.  that pot would cost me about $7.25 if I just order one.  that's over half of what I paid for the pcb, lol.
Quote from: Haberdasher on September 13, 2013, 02:45:12 PM
eeeeexactly
Haberdasher
Quote from: jimilee on September 13, 2013, 03:17:41 PM
eeeeexactly
Guitarmageddon
Grab a dual gang 1M from tayda and run both in series. ;)
Spud knows tone!
Captain Cod at
www.codtone.com
Quote from: Guitarmageddon on September 13, 2013, 08:22:07 PM
would that be pin 1 to pin 1 , pin2 to pin 2 and pin 3 to pin 3 on each gang?
Quote from: Haberdasher on September 13, 2013, 04:06:27 PM
eeeeexactly
What do you figure it would cost a guy to ship a 2mb in a small envelope?
Guitarmageddon
Quote from: jimilee on September 13, 2013, 09:06:48 PM
No. Wire to lug 1A, jumper lug, 2A to lug 1B, wire to lug 2B. 3rd lugs are unused. It puts the two halves in series. Fully ccw 0ohms, fully cw 2M.
Spud knows tone!
Captain Cod at
www.codtone.com
