Classy Tremolo
Started by pryde, February 10, 2014, 05:34:58 PM
pryde
Here is a vero-built EA Tremolo (with ROG improvements). The guitarist wanted something that looked and sounded "Fender-ish" so this fit the bill. Etched some copper and stuck an amp jewel in it (using 5mm clear LED to light it)
I still don't believe I have heard a better sine-wave tremolo than this circuit, it just sounds so very good. Note I am not talking about the original EA Trem but the "improved" one tweaked by ROG. Just a fantastic, warm tremolo reminiscent of Nancy Sinatra's "Bang-Bang"
Jabulani Jonny
That is a sweet build. Out of curiosity, what are the prescribed ROG tweaks?
Jonathan
pryde
The main change was the entire input stage was tweaked as well as some values for the depth an speed control. Here is a rundown from a ROG archive page:
http://www.home-wrecker.com/eatremolo.html
I have built both and to me it is a clear improvement in overall tone as well as how the tremolo sweep is balanced. The original has an overpowering low-end throb that seams out of balance.
mattlee0037
Love that etched copper. What's your method for rounding the corners/cutting. And did you etch spray paint then sand? Looks great
pryde
Quote from: mattlee0037 on February 10, 2014, 07:43:35 PM
The material is copper clad which already has a black background when you etch away the copper (same thing used for etched pcbs)
I have a benchtop belt sander to shape my panels and round the corners, then go around the edges with a small piece of 250 grit to smooth it all out.
billstein
J. Ignacio
Nice! Where i can find a tutorial to finish my pedal with pcb etching?
Thanks
Super clean build. Faceplate look perfect. Great job.
That's nice.  Straight and to the point.
pryde
Quote from: J. Ignacio on February 10, 2014, 09:36:53 PM
Thanks
There are some etching tutorials in the "members projects and tutorials section" including one that I did on etching aluminum enclosures:
http://www.madbeanpedals.com/forum/index.php?topic=11078.0
The process is the same really except you will use copper clad. (for these plates I use .030, 1-oz copper clad)
hoodoo
Very classy build mate, love the etched plates and  jewel  :)
Matt
Very nice build.  I did that version too but I sold it a while back.  Might have to build another one.
Matt
