Harbinger light not pulsing
Started by murdog47, March 13, 2014, 05:39:35 PM
murdog47
Rocked it before I boxed it and it was working fine. It is lit up and the intensity changes with the trim pot but it is staying lit and not pulsing. Haven't had a chance to run through troubleshooting yet. Anyone else run into this?
brejna
 I had similar problem with mine first univibe build and the problem was in R45 (in your case)... It was not gounded.. So you could check that.
pryde
#2
Quote from: murdog47 on March 13, 2014, 05:39:35 PM
Are any of the pots in a weird bind when tightening the nuts down? I am assuming they are pcb mounted? because of the dual-gang pot I had to add some spacers under the regular pcb mounted pots so everything would tighten flush to the enclosure.
