Connectivity Check/Question
Started by ddog, March 21, 2014, 06:26:27 AM
ddog
So Im building the Electric Boogaloo and I got a solder bridge between pins 6 and 7 of IC1. I cleaned it offbut Im still get connectivity signals from my DMM. I checked the schematic maybe there is supposed to be connectivity?
Here's a link
If so what I am not getting is that I am not getting any connectivity between 1 and 2 on IC2 (I soldered the resistor in)
pryde
pins 1 and 2 have a 10n cap between them so it will block a continuity signal.
pins 6 and 7 should be connected so you are fine there
ddog
Whew thats a relief. I was ready to start cutting traces.
How about 1 and 2 of IC2, the one with resistor. Should there be connectivity there?
pryde
Quote from: ddog on March 21, 2014, 02:34:58 PM
Well IC2 pins 1 and 2 are connected by the 220k resistor so yes they are connected together but you shouldn't get continuity between them (hence the resistor blocking the signal.
