Author Topic: Mysterioso Jr.  (Read 4753 times)
pandadandan
  • Stompbox Star
Mysterioso Jr.
« on: March 26, 2010, 10:28:24 AM »
Hot off the soldering iron!
Going to play with the cap values in the top switch; I think some parallel 500pf and 700pf ceramics would be good instead of the film caps.
  • Administrator
  • Brian
    • madbeanpedals
Re: Mysterioso Jr.
« Reply #1 on: March 26, 2010, 10:38:47 AM »
Awesome wiring! But, no pictures of the top side?? Anything interesting going on there?
pandadandan
  • Stompbox Star
Re: Mysterioso Jr.
« Reply #2 on: March 26, 2010, 10:47:31 AM »
Haven't finished really; still have to stamp out the controls on the copper plate.
For this one, instead of tarnishing the plate with salt water as I did with the Poindexter, I heated it until it was glowing hot, then threw it in our kitchen sink.  Made a lovely hissing sound  ;D
The wife wasn't impressed...
Re: Mysterioso Jr.
« Reply #3 on: March 26, 2010, 10:54:44 AM »
After looking at this and your other builds, I have to say that these are some amazing builds. What's the process of stamping those copper plates like?
Also, can I ask how you got your wires to hold such crisp right angles? It's a work of art in there!
pandadandan
  • Stompbox Star
Re: Mysterioso Jr.
« Reply #4 on: March 26, 2010, 11:04:38 AM »
Copper plates are stamped with a hammer and a cheapo set of 4mm alphabet stamps.
The wires are smallbear's amazing ***amazing*** pre-bond 24awg hookup wire.
I live in Japan, yet I still order the smallbear prebond stuff because it's so good.  A pair of pliers and a flick of the wrist are all you need for nice 90 degree bends.
Re: Mysterioso Jr.
« Reply #5 on: March 26, 2010, 11:09:36 AM »
Hey, that's exactly the wire I bought for the builds I'm working on now. I'll have to try it for myself.
pandadandan
  • Stompbox Star
Re: Mysterioso Jr.
« Reply #6 on: March 26, 2010, 11:28:36 PM »
Go for it!  Just don't try to flex it too many times or the bonding breaks down and it reverts to standard multicore behaviour.
I also recommend the switch wiring system I use; it negates the need for the optional pulldown resistors in a lot of builds as everything is grounded all the time.
1 2 3   -  -  -
4 5 6   -  -  -
7 8 9   -  -  -
Consider the numbers as the pin locations.
The ground wire goes from the ring of the input jack to pin 7, through pin 7 to pin 2 (bare wire) then to the ring of the output jack.  PCB ground goes to the input jack, too.
Input wire goes to pin 8 through to pin 3.
Pin 5 goes to effect input.
Pin 9 goes to effect output.
Pin 6 goes to output jack tip.
Pin 4 goes to your LED -ve.
This wiring layout lets you get some nice straight lines if you want to be as OCD as I am.  Hahah.
  • Josh
    • 1776 effects
Re: Mysterioso Jr.
« Reply #7 on: July 10, 2010, 06:42:10 AM »
How does it sound...?  Interested in possibly building this.
maysink
  • Solder Ninja
  • Erin (Irish; not female)
Re: Mysterioso Jr.
« Reply #8 on: July 10, 2010, 03:46:33 PM »
Quick question on the alternate switch wiring: How are you grounding the power adapter? I don't see anything completing the circuit--I see power going to the PCB & the LED but the ground lug on the adapter looks vacant...
I'm going to try this scheme for the hell of it!
[nothing to see here]
-e
pandadandan
  • Stompbox Star
Re: Mysterioso Jr.
« Reply #9 on: July 12, 2010, 10:38:54 AM »
It's the flash making it hard to see.  Look between the power ground lug and the input jack.  The ground lug is hardwired to the jack by a short (5mm) bare wire.   ;D
maysink
  • Solder Ninja
Re: Mysterioso Jr.
« Reply #10 on: July 16, 2010, 11:02:23 AM »
That's what I figured but even after you mention it I can barely see it! Tried this method on a gruntbox I finished earlier this week and it works as expected. I may try it on my byoc optical compressor which pops EVERY TIME regardless of cables, amp and power supply.
-e
