Aquaboy Deluxe issue
Started by harpplayer, April 22, 2014, 11:33:13 AM
jighead81
Got it working when I put in both IC's, but I've got some distortion on the repeats. I can't get a delay signal when I remove IC4 to calibrate IC3.  I'm using an MN3101 clock. Both IC's are getting the correct voltage, not sure about the clock though. When I plug in 15V to the abdx, my multimeter reads a drop down to 10v, just getting a reading from power in to the effect. Not sure if this is normal.
