I just ordered 2 of these!!!
Started by flanagan0718, May 23, 2014, 01:55:21 PM
Quote from: mmlee on June 04, 2014, 02:36:33 PM
Could some valve based things fit in those holes or are they too big?
Hmmmm. It would be worth checking! I was planning on doing a little watter.
Willybomb
Would have got some, but not for $39 shipping to AU.
GermanCdn
They're close, might actually be slightly on the small side for a 9 pin socket.  The bigger problem is that they are machined for two other large holes on the sidewalls as well.
blearyeyes
Well you could add some plastic eyeballs in the bigger holes and put blinking LEDs in them...
pk1802
I ordered one of the packs of 6 as well. My grouping looks a lot like everyone elses. I have one 1590bb drilled for a multi, A big pink box(1790?) drilled for 10 knobs, two 1590bs, one for 4 knobs and the other 2 knobs, and a 1590a drilled for two jacks, led and a switch.(I'm assuming a loop or channel switch).
Annnd then there is the silver guy with 4 giant holes. I was going to see if xlr's fit in the holes. I may make a two channel phantom power supply(as my mixer doesn't have phantom) and use the serial port looking hole as the power supply.
Ummm...to be PC I think the term "fat kid" should be "oversized young American"  ::)
That orange 1790NS looks like it could be a bad Blackout Effectors enclosure...
Quote from: gordo on June 05, 2014, 12:14:59 AM
haha. You're right , I'll watch my mouth next time ;D
Quote from: jkokura on June 05, 2014, 06:34:06 AM
I was thinking about putting a reverb/delay 2 in 1 in that bad boy!
