Lovetone PORN!!!
Started by Govmnt_Lacky, June 29, 2014, 03:51:02 PM
Beautiful and inspiring work!
Lordy!  These are killer
Quote from: alanp on June 29, 2014, 05:57:10 PM
Can't wait to see how you're going to mount the Ring Stinger's daughterboard with transformers in those relatively cramped enclosures :) (I wimped out and used a 1550G, not a D!)
There appears to be enough depth to mount it on the side.
Its easily done with standoffs.
Ian,
Is that a 1590D?
Another thing is that the String Ringer PCBs are a bit smaller than the real deals.  :-\
Quote from: Govmnt_Lacky on June 30, 2014, 04:31:10 AM
Ian,
Is that a 1590D?
no but its 55mm deep, which your enclosures seem to be.
the point is the board should fit mounted similarly to the way shown on my builds.
Quote from: LaceSensor on June 30, 2014, 05:03:35 AM
Will definitely keep that in mind!  ;)
Thanks!!
 8) so very impressive  8)
mmlee
The little chicken knob detail makes it! So good!
>Marcus
Awesome and impressive to the max...! 8)
blearyeyes
Wow!
Serious Awesomeness Builds!
When I grow up I wanna build things like that!
Sheesh..
chuckbuick
Holy wow!!!  Real beauties.
Quote from: chuckbuick on June 30, 2014, 07:02:19 PM
IIRC, PD built a MuTBall Meatball-in-a-1590A which YOU laid out? ;)
What I really like about Govt's Meatball is that he's done it on a replica of the original PCB. Actually... Greg, any chance of a photo of the component side of that one? :)
Wow. This is amazing and crazy lot of wiring inside (flange). Looking forward to my builds.
Quote from: alanp on June 30, 2014, 07:28:21 PM
Possibly. I am having some switch popping issues with the Meatball currently and I may need to remove the "innards" to examine whether of not I reversed a lytic cap or something...  :-\
I will be putting out some pseudo build docs with trace transfers, component location diagrams, and off-board wiring diagrams for the Meatball as well as the Wobulator and Ring Stinger once I get the last two completed  ;D  8)
Im not gonna do a fancy sch-many build doc but it will be enough for anyone to build their own full-sized monster!!   ;)
jtn191
sick!! I want to build some Lovetones some day...would be cool if there were more Lovetone/synth style designs...
