Author Topic: Suggested Pots for Chunk Chunk  (Read 2097 times)
cpsmusic
  • Diode Destroyer
    • View Profile
« on: August 23, 2014, 06:53:51 AM »
Hi,
I've finally got around to building my Chunk Chunk. I've assembled the board however I've bought the wrong type of pots - the lugs have a 90 degree bend but they have eyelets rather than pins. Also, the eyelets don't go past the base of the pot so even if they were pins they wouldn't be long enough for mounting.
Could someone point me to the right sort of pots to mount on a Chunk Chunk board. BTW, I'm in Melbourne, Australia.
Cheers,
Chris
  • Administrator
  • Electron Doctor
  • Brian
    • View Profile
    • madbeanpedals
Re: Suggested Pots for Chunk Chunk
« Reply #1 on: August 23, 2014, 07:10:37 AM »
Chris,
You can still use the lug pots. Just make small wires to go between the pots and pads on the PCB as if they were mounting pins. I do this all the time when I run out of right angle mounted ones. And, they are very stable this way.
mgwhit
  • Electron Doctor
  • Matt
    • View Profile
« Reply #2 on: August 23, 2014, 09:51:49 AM »
What Bean said, but I use cut off resistor leads for this.
  • Administrator
  • Electron Doctor
  • Brian
    • View Profile
    • madbeanpedals
« Reply #3 on: August 23, 2014, 10:21:14 AM »
Yup, even better.
Lately I have been using 22g buss wire. There is nothing I hate more than stripping and soldering wires.
cpsmusic
  • Diode Destroyer
    • View Profile
« Reply #4 on: August 23, 2014, 05:48:22 PM »
I was thinking that stiffer wire would be better. I had the resistor lead offcuts but I threw them out - doh! I'll dig out some stiff wire from somewhere.
Out of interest, what are the right sort of pots for the Chunk Chunk?
mgwhit
  • Electron Doctor
  • Matt
    • View Profile
« Reply #5 on: August 23, 2014, 06:59:34 PM »
Sorry!  Forgot that that's what you were asking in the first place.  Look for "PCB terminal" pots like this.
blearyeyes
  • Electron Doctor
  • Like so many others, my name is Dan.
    • View Profile
« Reply #6 on: September 09, 2014, 07:23:46 PM »
I learned about wiring solder lug pots for PC right angle from a Mad Bean tutorial and an unintentional benefit is they are more forgiving when you drill your enclosure. If your a little off, the wired pots move more easily to accommodate the differences.
I sometimes build pedals as "Dan"
I built peddles for Bat Thumb’s car.
cpsmusic
  • Diode Destroyer
    • View Profile
« Reply #7 on: September 09, 2014, 08:45:48 PM »
Whereabouts is the tutorial?
blearyeyes
  • Electron Doctor
    • View Profile
« Reply #8 on: September 09, 2014, 08:50:36 PM »
It was a build tutorial for the ZeroPoint SDX I'll see if I can find it.
blearyeyes
  • Electron Doctor
    • View Profile
« Reply #9 on: December 10, 2014, 08:31:15 PM »
This is one of Brian's build reports where he uses solder lug and make them into PC mount pots:
http://www.madbeanpedals.com/builds/reports/zpsdx/index.html
cpsmusic
  • Diode Destroyer
    • View Profile
« Reply #10 on: December 11, 2014, 05:09:48 AM »
Thanks! Nice build report - I learn a lot from these.
