Who designed the sea flea?
Started by jimilee, September 02, 2014, 06:03:21 PM
My regulator is getting warm, and I got no delay. I have resoldered, I have run a blade through every joint, verified all the caps are in the right spots. I'm stumped, I tried another regulator, does the same thing. Is there a part that has gone bad? Is there a schematic? I took a solder side picture, I'll take more this evening.
I believe it was AlanP. It's based on the DBD
Quote from: flanagan0718 on September 02, 2014, 07:29:46 PM
I believe you're right. It was based on the dbd, just 1590a style.
Here is the link (it was Alan)
https://oshpark.com/profiles/alanp
Seems like a dumb question, especially someone with your experience, but is the pin out on your regulator the same? I had this happen on a Rebote 2.5 I built a little while ago and I think the solve was I flipped it 180 degrees.
I flipped it even though it matched the silkscreen, no dice.
The part numbering doesn't match up between the Sea Urchin and Sea Flea.
Quote from: alanp on September 02, 2014, 07:54:36 PM
I'll check what I have when I get home. I hope that's it, otherwise  finding "the" bad part is a pita
Parts match up to the bom, I'm at a loss.
Junk PT2399 maybe? The polarities on the ele caps right?
Quote from: flanagan0718 on September 03, 2014, 12:21:15 AM
Polarities are good, damned resistors are so small, I can't really read them but just comparing them to what I can see, they're right.
So R7 is the ony resistor that would affect the regulator?
No, R7 and R8 provide Vbias, the regulator is directly attached to 9V and puts out 5V on the VD net which is directly connected to the PT2399.
That's what I was thinking, bit I was hopping I was wrong. This one has me stumped.
Check the voltages on your regulator and make sure they're what you should be getting. Off the top of my head I think you should be seeing 5V at pin 1 of the PT2399 if that's an easier spot to measure...
