Nom Nom 2015 no sound (solved)
Started by Tom S, February 19, 2015, 11:02:46 AM
Tom S
I am getting no sound from my Nom Nom 2015.  I have tested all voltages from both ICs and they are showing values equal to the specs in the manual.  When I applied my sound probe I received sound only up to the 1st leg of C1 (10nF cap).  C1's output has no sound.  I have replaced C1 with a different cap but that did not fix the problem.  Sound signal does not seem to be getting passed that component/area on the board.
A few things to note about my build:
Q1 is a 2N5087
Q2, Q3, Q4, Q5 are 2N5952, so I turned them 180' on installation as their pinout is opposite of the suggested 2N5457
trannies.
Any ideas what is causing this or what I have done wrong?  Any advice would be appreciated.
-Tom
Hi Tom,
You have used a 470R for R2 instead of 470k. That's your problem for sure.
Other than that your build is looking very nice. Please double check your other resistor values.
Tom S
#2
Quote from: madbean on February 19, 2015, 11:14:45 AM
Hi Tom,
Wow, thanks for the incredibly quick reply.  I will get right on changing that resistor.  Looks like I may have also made the same mistake with R24 (the other 470K).
Thanks!
-Tom
Tom S
Yep that did it.  Replaced R2 and R24 with the appropriate values and I have sound.
Thanks again.  Lesson learned, always double check resistor values before installation.
