Resistor Values for LED's
Started by billstein, April 24, 2015, 06:12:03 AM
billstein
Hi all. Just a quick question. What resistor values do you use for Led's.
1. For diffused?
2. For waterclear?
Thank you
I use 10K for water clear high brightness LEDs. Works good for me.
For 9V? 4K7 for normal.
Swearing for different.
Quote from: alanp on April 24, 2015, 08:24:52 AM
Well 10 K is  a little less bright than 4k7 but still enough to light up my music room when my board is powered up.... just not too retina scorching.
Mich P
Diffused      :     1 to 4.7K
Waterclear  :  15 to 100K
Mich P.
HKimball
Wow that explains a lot - I just use 4.7k for everything haha. Makes sense now why my white LEDs on my 18v pedals are like staring into the sun
muddyfox
yeah I'm with Mich. All over the place, depending on the application.
Quote from: cooder on April 24, 2015, 07:54:56 AM
Great to know! I've never even thought about it, just complained to myself.
I have a lot of random LED's (sorted by colour) from many different suppliers, diffused/clear, three sizes etc., i check each one before installing to get the appropriate clr and that has ranged from ~500r to 47k. Have a box with 24 steps  from 500r to 18k to test for a clr value.
billstein
Quote from: davent on April 24, 2015, 03:52:27 PM
That's a great idea.
Is that resistor on the left a safeguard so you don't apply to much voltage and burn out the LED?
Is that a 1x12 rotary switch?
Usually between 1k and 5k for diffused and between 15k and 20k for ultraclear.
Quote from: billstein on April 24, 2015, 04:12:35 PM
That's just a 10k that gets added in series with other 12 resisitors  so you get the next 12 higher steps.
Have an amp with  a bicolour led that needed a quite different clr for each colour to achieve equal levels of brightness, there is no one size fits all.
billstein
Thanks guys.
I always use 4k7 for diffused but tried a waterclear blue with 4k7 and now I think I need to replace the retina in my eye! :)
So, just wanted to know if there was a consensus out there for the high brightness LED's. I'm hearing anywhere from 10K all the way to 100K.
I might have to build a tester like davent.
guile
Completely OT: wheredid you find that LED-tester? Would love to have one
Just a bunch of random bits gathering dust thrown together into something useful. Idea was put forward by Mark Hammer over at diysb.
