Nameless
Started by alanp, January 19, 2016, 03:56:37 AM
Lovetone Flange With No Name, 1790NS sized! Major crammage going on here, as you can see --
More wiring than I like, but them's the breaks. The Loopage stomp and two jacks are omitted in this version, as are the two expression jacks. Everything else is here, including mad oscillation :)
I'd forgotten just how damn good this circuit is at subtle phattening. I can't get the A/DA to do that.
I've got some v0.2 boards coming for the audio path, once I do I'll see about some guine--er, paying testers to give 'em a crack (and shoot Chris a working audio board.)
Pics for historical purposes :)
diablochris6
Looking good! I can't wait to see what kinds of wild sounds I can get out of this. I'll have to take my time with this one...it doesn't look like a build for the faint of heart!
I suspect I'm going to wind up putting off a build doc for as long as I can, simply to avoid having to do a wiring diagram  :o :(
Awesome Alan, can't wait to try my hand at this effect. Looks like a beast.
Jebus
Awesome! So cool layout and build 8) 8) 8)
Sweet ass, I can't wait to give it a go, Flangers might be my other thing.
Aristatertotle
Alan...
Are there provisions on your PCBs to add the Loopage and jacks to build a complete unit?
I would definitely be interested in a set when the corrections are made  8) I think you, Lace, and I were the major players back when Jim was working on this...  ;)
Wowzerz!  Almost enough to make me think about thru hole again.
Greg, with some offboard wiring and bodging it could be done... I did not plan on doing expression jacks and loop with this, since I knew I'd be pushing my luck as far as 1790NS space goes.
Symmetrical board stacking!  :o No human would stack boards this way!
8)
Martan
#12
Wow! That is really excellent. I know from reading the threads BP (before purge) that a massive amount of work went into this. Congratulations!
Quote from: juansolo on January 22, 2016, 07:26:31 PM
8)
Listen -- do you smell something?
Right, the v0.2 audio board is on it's way, so if this works with no patching needed then I'll look into doing a 25 board run or something. Don't put your hand up in this thread, I'll start another one when I do order them.
I've got an idea in my head of doing a multi box -- Lovetone flanger, phaser, overdrive, and trem, Madbean reverb, and maybe the DI board at the end for the XLR out.
