Thanks for all the kind words.
Painting boxes takes so much time, and waterslide decal is difficult to work with.
With a Polished aluminium-box and permanent-marker with some colorful knobs you'll can complete the whole build in hours instead of days
This is my first build with PCB-mounted pots, it's space saving and makes pedal clean inside.
If you look closely at the electrolytic cap you can see it's a bit messed up. (only cosmetic)
I had to use a file to trim the PCB a bit to make it fit in the box
