Re: An IC Quandary
Started by K3yPr0gg3r, May 01, 2016, 11:54:16 PM
K3yPr0gg3r
Hi,
On Mouser, Tayda, Small Bear, etc. I keep finding extra letters attached to IC/Transistor types I need. Example: I need an OPA2228 IC, and I find OPA2228PA or OPA2228P... Are these identical to the listed component needed?
Thank you
Look up the data sheets to compare them. Great learning experience. USUALLY there are similarities enough to say they are the same.
The suffix can mean a few different things. Generally they indicate either package type or temperature range. Sometimes other things. Most of the time you are safe ordering any given one but do make sure you are getting DIP and not SMT (unless you are building surface mount).
As Jimi said, looking at the datasheets are a good habit to get into. Often they will lay out in a grid exactly what each suffix means.
K3yPr0gg3r
There was some thermal info. on the data sheet. The biggest difference I noticed was in the Vos - Input Offset Voltage. OPA2228PA had 200uV, where as OPA2228P had 75uV. Not sure if this matters...
galaxiex
Quote from: K3yPr0gg3r on May 02, 2016, 12:49:07 AM
In this case I think the difference is a tighter tolerance for Vos. Probably won't matter.
Does the OPA2228P cost more?
K3yPr0gg3r
Yes. $9.75 vs $5.30...I figured the one with a greater Vos would be more expensive...   ?
galaxiex
Ummm, No.
Large input offset voltage might be considered a bad thing in some applications, (precision electronic measuring instrument)
so a lower value for Vos means the part has a better (tighter) tolerance in this regard.
For pedal building it likely won't matter, and you would be hard pressed to hear any difference.
