Lab Series L5 preamp in a pedal
Started by aion, May 02, 2016, 01:03:29 AM
slacker775
I agree.  The couple bucks in power section bits is minuscule compared to all of the other parts and the PCB.
admst
thanks gents. i was thinking more in line with putting this in an enclosure with another +/-15v pedal and powering them both from a separate power supply - which, in theory should work if they are connected in parallel i believe.
If you heatsinked the regulators on the Lab Series board (you'll need a tall enough enclosure), you might be able to run the other board off it. Depends on current draw.
admst
#123
interesting, thank you kindly. have you done something like this before?
do you have any resources or links you can share on that topic so i can do some research?
cheers
vanzea
Amazing build. If somebody wants to sell his pedal, I'm interested!
