Re: 1PDT...?
Started by K3yPr0gg3r, May 10, 2016, 09:06:32 PM
K3yPr0gg3r
Hi,
I have a TH Custom Effects build that calls for a 1PDT switch (toggle?). Did a brief search, and kept coming up with SPST or SPDT. Does this actually exist or is this a type O.
Thanks,
dbp512
a 1pdt is the same thing as a spdt. the s stands for single, and the d stands for double. Larger than that they switch to numbers to keep things simpler.
"you truly are a transistor tickler, what with the application of germanium ointment to sensitive fuzzy areas. :)" - playpunk
Single pole double throw=spdt or 1pdt
K3yPr0gg3r
Hey...Thank you. Guess I should have figured that. Build is coming from Germany, so I guess they have their own jargon there as we have here. It's a "Wet" switch, so I'm wondering if a simple SPST (On/Off) would serve...?
Thanks again
dbp512
Its hard to say without looking at the schematic, and TH has too many for me to know which one you have. Probably, since its easier to use a double throw as a single throw instead of having to keep 2 different parts in stock. But theres a chance it needs the second throw to do its thing properly.
K3yPr0gg3r
It's the Jenny, and now that I have an actual picture of a finished product in front of me I can use an SPDT (on/on). One way for "wet", and one way for "dry". I need to remember to keep this building thing simple... ;D
Quote from: dbp512 on May 10, 2016, 11:50:54 PM
I blame the metric system.
Quote from: jimilee on May 11, 2016, 12:43:52 AM
I actually blame the non-metric system you guys use... pounds per square inch? I mean, come on! why not use Pascal instead? we all should just use SI units, which incidently happen to be in metric units :)
Quote from: m-Kresol on May 11, 2016, 07:35:32 AM
Metric is too precise for muricans, over yonder would never make it in the metric system.
dbp512
Quote from: jimilee on May 11, 2016, 12:03:46 PM
Except for temperature, for some reason Fahrenheit is more accurate than Celsius. But really, as long as I can still buy beer by the pint I'm good.
you know that american and brithish pint are different too, right? If you're in the US, the metric system would benefit here to as our beer comes in 0.5L.  8)
dbp512
Quote from: m-Kresol on May 11, 2016, 01:50:32 PM
Well now theres no reason not to switch.
solderfumes
Had to ask an old guy at work about a list in a joke, today.
"What's one ell bee?"
"One pound."
"So... maybe 450 grammes? What's a quart?"
"Uh... a quarter litre maybe?"
