Re: Shielded Wire
Started by K3yPr0gg3r, July 25, 2017, 10:47:35 AM
K3yPr0gg3r
Hi,
This has been posted, but has not been addressed specifically. I'm beginning to build the "Chunk Chunk" PCB. In the build docs Brian recommends using shielded wire on either the input and/or the output jacks. I use daughter boards from either (Ben) Rullywow, Fuzz Dog, or (Paul) DIY Guitar Pedals. I've found shielded wire at SB (RG-174), but I'm wondering if it will fit daughter board pads? I usually use SB 24 pre-bonded.
Thank you
Short answer = YES
RG-174 is equivalent to probably 24 or 26 gauge with respects to the center conductor. I use it all the time and never had an issue.
P.S. For the Chunk Chunk.... use it on BOTH the Input and Output. You won't regret it  ;)
K3yPr0gg3r
Hey... GREAT! I've got an order to place with SB tonight so I guess I'll get two feet ... just to be safe. Thank you for the clarification.
