Author Topic: Pine-o-clean tremolo  (Read 7427 times)
  • Matt
    • My pedal blog
« on: July 30, 2017, 03:25:49 AM »
I posted a build report the other week about part of my kid's school science project - a tremolo build.  (http://www.madbeanpedals.com/forum/index.php?topic=25928.0)
Here's the rest of the project - he has built a tremolo using a motor, spring, container, and liquid sloshing around.  There was much science done testing different liquids, and in the end 'Pine-o-clean' was chosen as the tremolo liquid of choice.
It has two configurations with the container upright wobbling, or horizontal being bounced back and forwards in a pipe.  Amazingly (well, to me anyway) this works out as an almost sine wave tremolo and a square wave, respectively.
The tremolo has a bit of randomness to it... sometimes the waves come in groups of two or three close together, then with a bit of a gap.  It's a pretty cool sound.
Example of the waveform coming out of this thing:
He also played around with a solenoid instead of the motor, but that bit isn't finished yet.
The 'guts':
A 30 second video of it working:
http://graybloomfield.com/guitar/2017/07/30/liquid-tremolo/img_1758/
And a 5 minute video if you want more 'science':
http://graybloomfield.com/guitar/2017/07/30/liquid-tremolo/science2017-480/
  • Felix - Graz, Austria
    • My blog - in german
Re: Pine-o-clean tremolo
« Reply #1 on: July 30, 2017, 05:30:05 AM »
this is all sorts of cool. Very creative!
« Reply #2 on: July 30, 2017, 05:33:18 AM »
So, basically the liquid sloshing is changing the resistance between two poles and shunting some signal to ground? Or just straight up attenuating the signal?
PhiloB
« Reply #3 on: July 30, 2017, 06:26:08 AM »
Looks like it was a lot fun.  Great memories
mattc
  • Solder Ninja
« Reply #4 on: July 30, 2017, 09:47:46 AM »
That's awesome!
  • Jon P
    • Midway Fair
« Reply #5 on: July 30, 2017, 11:13:59 AM »
Awesome. The extra science video was also very good.
  • Eric K. (personal pronouns: he/him)
« Reply #6 on: July 30, 2017, 11:37:57 AM »
I've bookmarked this to look at carefully when I can spend time on it and enjoy.  I'd love to do some modified version of this with my daughter sometime.  She is always asking to help with my projects.
Luke51411
« Reply #7 on: July 30, 2017, 12:15:18 PM »
That's so cool 8)
  • Corey - Christchurch, NZ
    • Soundcloud
« Reply #8 on: July 30, 2017, 03:13:00 PM »
Surfin wth the Alien! 8)
Very cool project
  • Matt
    • My pedal blog
« Reply #9 on: July 30, 2017, 03:59:29 PM »
Very cool project
Well picked.  That's the song he's learning at the moment. :)
  • Matt
    • My pedal blog
« Reply #10 on: July 30, 2017, 04:03:44 PM »
Yep, the liquid shorts between signal and ground.  What amazed me is that it wasn't necessarily an on/off effect.  It had definite ramping on and off, depending on the angles of the wires and liquid movement.
I was also surprised that tap water is a pretty crap conductor for these purposes.  Salt water was much better.  Pine-o-clean was the bomb.
« Reply #11 on: July 30, 2017, 04:41:44 PM »
Resistance is a function of distance! Grab a glas of water and stick your DMM leads in 1cm apart and check the resistance (Pure water is 18.2M/cm, My "filtered" water is about 1M, my tap water is like 20k and tastes like pool run-off). Then move them closer, then further apart. By sloshing you're changing the liquid distance between the two poles, so variable resistance.
Very cool project.
  • Matt
    • My pedal blog
« Reply #12 on: July 30, 2017, 09:06:04 PM »
Lol... Our tap water was about 500k with the leads 1cm apart.
from memory, whiskey was pretty bad at conducting too.  I got to drink most of the test subjects.  Not the cleaning products though.   :P
diablochris6
« Reply #13 on: July 30, 2017, 10:43:43 PM »
Gold medal stuff here. Jack White will probably try and buy this from you at some point.
« Reply #14 on: July 30, 2017, 11:07:58 PM »
Man your tap water is better than the "6x filtered!" water I buy from the machine at the leasing office, thats just annoying. Yeah my local water has an absurdly high calcium content (desert ground water) and a stupidly high chlorine level because of a bad diatom problem we have in southern AZ. Tap water will go slimey and coat things in a lovely golden brown layer of goop in as little as a couple days, and when they tried lowering the chlorine dose everything started to smell like geosmin and methylisoborneol (ie: muddy and mildewy).
But, hey, at least we get cool things like being able to grow stalactites off our faucets, so that's something I guess.
