Author Topic: Pedalpcb.com demos ?  (Read 10176 times)
Yahoo67
  • Solder Ninja
« on: January 24, 2018, 02:46:14 PM »
I cant seem to find any pedalpcb.com fv-1 Demos on the web :/
As anyone build one on this forum ? Do they sound any good ?
fair.child
Re: Pedalpcb.com demos ?
« Reply #1 on: January 24, 2018, 03:24:01 PM »
Yes, it sounded awesome. Plus, Rob is a great guy when you are stuck or get any issue with the build. I will try to make a quick demo this weekend for my finished Glimmer. It's a definitely a go-to pedal for the post-rock style/worship music.
Yahoo67
  • Solder Ninja
« Reply #2 on: January 24, 2018, 03:57:57 PM »
Cool :) i just ordered a fv1 chip, Organ donor pcb and a phaser 2  pcb just to get the free shipping :D
Really curious how diy digital pedals sound ^^ hope that he makes more. Weird how some of the layouts of fv1 chip pcb are identical... all that must be different is the program on the rom chip. NEED a digital synth pedal !!
bsoncini
  • Solder Ninja
« Reply #3 on: January 24, 2018, 04:02:20 PM »
Just noticed he is coming out with a multi effect. Curious about this one. http://www.pedalpcb.com/product/octagon/
dan.schumaker
  • Schu-Tone
    • Schu-Tone
« Reply #4 on: January 24, 2018, 05:51:54 PM »
The Organ Donor does sound awesome, very comparable to the EQD organizer
Philthy
  • Solder Ninja
  • Oz
« Reply #5 on: January 24, 2018, 06:54:29 PM »
Yes please
fair.child
« Reply #6 on: January 24, 2018, 06:55:20 PM »
Wow, tempted to build one actually
  • Administrator
  • Brian
    • madbeanpedals
« Reply #7 on: January 24, 2018, 07:36:16 PM »
I'd kinda like to build the Organ Donor, but I've noticed that the schematic/build notes still haven't been released. So, I dunno.
Matmosphere
  • Matthew
« Reply #8 on: January 24, 2018, 08:06:49 PM »
Wha, somehow Ive never watched a demo of the organizer?! It sounds fantastic. Id like to see the documentation as well. This one might stave off my need to finally pick an EHX 9 series pedal up.
« Reply #9 on: January 24, 2018, 08:13:48 PM »
Interesting. Wouldn't be difficult to turn that 8 effect pedal into a 15 effect pedal, would just need to wire a switch onto the ground side of that 10k resistor under the EEPROM.
« Last Edit: January 24, 2018, 08:16:27 PM by somnif »
« Reply #10 on: January 24, 2018, 09:11:48 PM »
I also just realized how many of their PCBs are identical save for the EEPROM they come with. Fascinating. Makes sense I suppose, why bother designing a new board if its the same architecture.
fair.child
« Reply #11 on: January 25, 2018, 01:24:40 AM »
Just emailed Rob and he said it uses the 100k linear pot to change between the presets. I asked him whether there is a way to trick switching nicely between the presets. Perhaps, 8 poles rotary switch.
« Reply #12 on: January 25, 2018, 01:49:25 AM »
Yeah he has a little microprocessor on the board that will play the role of the 3 toggles the FV-1 is designed around (the ATINY85 chip). So like, 0-12.5k = (0-0-0), 12.5-25k = (1-0-0), 25-37.5k = (0-1-0), etc etc etc. (I mean the resulting voltage from those resistances, but same diff)
In theory you could set up the same deal with a rotary and resistors in series. It would be a bit of a pain to fit in the box though, not a lot of room in a 125 to spare.
What I meant about the 15 effect thing was, the way he has it set up is it will use 8 effects from the outboard EEPROM chip. BUT, the FV-1 also has 7 (plus one blank) effects built into it. If pin 13 sees a 3.3V signal, it uses the stuff on the chip. No 3.3V, it uses the onboard stuff. To do this, you wire a switch on that 10k resistor under the eeprom, flipped up the juice flows to the FV-1, flipped down it goes to ground.
This would give you all 8 effects on the EEPROM, plus the 7 defaults. Super simple.
Also, because he was nice enough to use a through-hole design for the EEPROM, all you need is to socket it and you could swap out effects for the price of a new chip. All manner of fun patches out there to play with, or design your own.
« Reply #13 on: January 25, 2018, 01:54:20 AM »
(Ah screw it, I just bought the octagon and a chip. Ramen for a week it shall be!)
Pentadecagon, here I come!
fair.child
« Reply #14 on: January 25, 2018, 02:30:36 AM »
Wow, that was escalated quickly.
