Author Topic: BOSS CE1 PROJECT: MN3002 or TDA1022P: DOC UPLOADED  (Read 49522 times)
drog_trog
  • Guest
« on: March 14, 2018, 07:09:54 AM »
UPDATE:
BUILD DOCUMENT: https://drive.google.com/file/d/1A7INECxk7Rbwl47o64qhp7koKuqXpupU/view?usp=sharing
SCHEMATIC: https://drive.google.com/file/d/1MhTZEpOqMkA0MQJ3cPFBNJ45Y3ySNcCh/view?usp=sharing
BOSS CE1...'King of Chorus' which is based on the Retro Sonic Chorus
Prototype build
Hopefully I will get around to putting it together in a shiny new enclosure all properly complete including a demo.
« Last Edit: September 10, 2018, 03:45:50 PM by drog_trog »
thesmokingman
  • Electron Doctor
    • View Profile
    • A Cult of ACK
Re: BOSS CE1
« Reply #1 on: March 15, 2018, 12:44:49 PM »
did you make any improvements for use with guitar?
kaeisy
  • Transistor Tickler
    • View Profile
Re: BOSS CE1
« Reply #2 on: March 15, 2018, 01:32:25 PM »
Wohaa! Looks great! A prototype build. Will there be a board available somewhere?
dan.schumaker
  • Electron Doctor
  • Schu-Tone
    • View Profile
    • Schu-Tone
Re: BOSS CE1
« Reply #3 on: March 15, 2018, 02:57:55 PM »
Totally in on a PCB when they are available!
(now to source a MN3002  :o)
drog_trog
  • Guest
Re: BOSS CE1
« Reply #4 on: March 15, 2018, 03:50:39 PM »
Itís an exact copy of the retro sonic chorus which works well with guitar. just gotta sort out the stereo bit and also have a poke around with a scope to properly adjust the bbd output trim pot.
I would also need to make an adjustment so people can source their own dc-dc module, mine is a +/-14v(Runs from your regular 9V. ), same as the retro chorus. Leave it with me and I will work on these issues.
« Last Edit: March 30, 2018, 05:41:45 PM by drog_trog »
cajone5
  • Electron Doctor
    • View Profile
Re: BOSS CE1
« Reply #5 on: March 15, 2018, 04:55:40 PM »
Cool project. Would also be down for a PCB if you make them available in the future. Thanks for sharing!
  • Electron Doctor
  • Jon P
    • View Profile
    • Midway Fair
Re: BOSS CE1
« Reply #6 on: March 15, 2018, 07:58:30 PM »
This is awesome. I think this is the first CE1 build I've seen.
  • Electron Doctor
    • View Profile
    • Project Website
Re: BOSS CE1
« Reply #7 on: March 15, 2018, 08:56:45 PM »
This was by FAR the coolest pedal I ever owned and have been kicking myself ever since I sold it a bazillion years ago.  This is VERY exciting indeed.  I've heard stuff that was close but never duplicated.
Vaxed, boosted, ready to rock...
drog_trog
  • Guest
Re: BOSS CE1
« Reply #8 on: March 16, 2018, 03:58:56 AM »
Donít worry if you canít get an MN3002, Im going to make an expansion board to accommodate the TDA1022, another 512 stage BBD which Iíve tested and works just as good PLUS Iím also going to try get an MN3007 to work with a bit of tinkering.  :)
  • Electron Doctor
    • View Profile
Re: BOSS CE1
« Reply #9 on: March 16, 2018, 04:33:50 AM »
Wonder if it would work with a slightly re-wired mn3001 (since I can lay hands on the NTE version of that thing....)
chordball
  • Solder Ninja
    • View Profile
Re: BOSS CE1
« Reply #10 on: March 16, 2018, 06:49:50 AM »
Nice! I'm down for one when you get them sorted.
drog_trog
  • Guest
Re: BOSS CE1
« Reply #11 on: March 16, 2018, 08:52:18 AM »
Can you guys do some digging for me. We want a cheap DC-DC converter 2W that is easy to source. Ideally less than $10 in a SIP-Package. Output to be Ī15 VDC or Ī14 VDC ideally. these are the specs of the 1 im using now.
  • Electron Doctor
    • View Profile
Re: BOSS CE1
« Reply #12 on: March 16, 2018, 01:53:34 PM »
That is a remarkably frustrating set of specs.
Only +/-14V converter I can find has a 5V input and a 1W max rating. Bleh. Of the 2W 15V'ers, the cheapest I can find with a 9V input is 14$.
I shall keep digging!
  • Electron Doctor
    • View Profile
Re: BOSS CE1
« Reply #13 on: March 16, 2018, 07:08:51 PM »
Looking at some other folks who have cloned it, is appears others have gotten away with a combination of charge pumps, inverters, and regulators to get the voltages they needed.
  • Electron Doctor
  • Jon P
    • View Profile
    • Midway Fair
Re: BOSS CE1
« Reply #14 on: March 16, 2018, 09:42:53 PM »
Two watts?  :o
How much current does this thing draw?
i would just drop +-15V and drop it with diodes.
