Author Topic: New Projects Are Up!  (Read 1201 times)
  • Administrator
  • Electron Doctor
  • Brian
    • View Profile
    • madbeanpedals
« on: September 21, 2019, 09:07:06 AM »
The VFE Bumblebee, Harbinger 1.5, Man O' War and Man O' War DLX are now available. The Snarkdoodle giveaway is also in effect until I run out. The Polytrog has to be pushed back to Oct. due to a very stupid error I made on the PCB which will re-quire them to be re-run. Very sorry about that!
Stupid Polytrog story:
I verified my final prototype quite a while back. I discovered a minor error in how I had two diodes connected. No big deal, fixed that on the PCB and had them made. I decided I better build up a production board once I had them since it is such a complicated project and there were also a couple value changes I forgot to include in my prototype. So, I build the board, test it out. No dice. Not getting the right voltages off the charge pump. I think and think and think. Then I realize I drew the charge pump circuit wrong. When I built the prototype, I just powered it off 18v to start since I did not know what the final current draw was going to be. After I verified it I thought...well, I did not put the parts on for the charge pump so I better check that out. Rather than solder the parts on the PCB, I quickly breadboarded it and verified it worked with the total circuit. Big mistake (thinking I left nothing to chance...other than the possibility that I did the circuit wrong on the PCB). I've drawn that charge pump hundreds of times why would I make a mistake?
Goes to show - never leave even the smallest detail to chance when you are designing PCBs.
I own madbeanpedals (duh). I am part owner of Function F(X).
  • Solder Ninja
  • Dan
    • View Profile
Re: New Projects Are Up!
« Reply #1 on: September 21, 2019, 09:53:08 AM »
Order in! So pumped for the bumblebee, thank you.
Doorlord
  • Diode Destroyer
    • View Profile
« Reply #2 on: September 21, 2019, 01:26:13 PM »
ordered my Harbinger.
Not sure when I'm gonna get to build it though, as I'm currently emptying my garage/shop for a 3 month construction project. Adding a room and moving the garage door to another wall, which will require a new garage slab so the water & beer will drain out instead of in. Demolition starts Monday AM.
dawson
  • Transistor Tickler
    • View Profile
« Reply #3 on: September 21, 2019, 04:00:37 PM »
Heroically high standards to call this a "stupid" mistake.
oip
  • Stompbox Star
    • View Profile
« Reply #4 on: September 21, 2019, 08:11:52 PM »
nice!  harbinger ordered.  looking forward to this one.
Axldeziak
  • Diode Destroyer
    • View Profile
« Reply #5 on: September 22, 2019, 05:42:27 AM »
You could blow out the Polytrog boards you already have as unsupported seconds, (or as a giveaway) and let the builder worry about the 18V source.
It would be a way to get some use out of them without the pile becoming landfill.
  • Electron Doctor
  • Jimi Lee
    • View Profile
« Reply #6 on: September 22, 2019, 08:42:24 AM »
Maaaaaannnn
HamSandwich
  • Solder Ninja
    • View Profile
« Reply #7 on: September 22, 2019, 09:20:03 AM »
Agreed with this. Hell, if that's the only problem, I'd buy one at regular price!  :o
Berger
  • Diode Destroyer
    • View Profile
« Reply #8 on: September 22, 2019, 10:26:29 AM »
Yup same here
zgrav
  • Stompbox Star
    • View Profile
« Reply #9 on: September 25, 2019, 12:44:07 PM »
No surprise to see that the Snarkdoodle boards are gone.  : ^)
  • Administrator
  • Electron Doctor
  • Brian
    • View Profile
    • madbeanpedals
« Reply #10 on: September 25, 2019, 12:52:41 PM »
I actually have some more on the way.
zgrav
  • Stompbox Star
    • View Profile
« Reply #11 on: September 27, 2019, 09:43:12 AM »
Mine is apprently in the mail, so no problem here.  But good to know that a few other folks won't be disappointed.
