more bite from my Runt build (SOLVED)
Started by powerplayj, February 05, 2020, 03:20:44 AM
powerplayj
My cut pot nearly entirely CCW, is almost perfect.  When turning CW, It gets muddy way too soon compared to a stock Rat.  I have checked cap values which seem ok, no solder bridges could be found and I typically double check my resistor values before I populate the board.  is there a critical component which the lack of tight tolerance could critically affect the lack of treble getting through?  I'm using metal film resistors.
Did you use a log taper or linear taper pot? Linear tend to get there quicker in any build.
powerplayj
All my pots are 100kA, I believe...just like OEM Rat.  My problem is that I would like a bit more treble than what I get at full CCW on the pot.
At full CCW the tone circuit basically does next to nothing as far as rolling off high end. You could try a 47pF in place of C4. That would give you a bit of high end back.
powerplayj
#4
Changed out C4 for another ceramic 100pf cap.  ....Huge difference!!!..... much better response above and below the desired cutoff frequency.   I  will assume I got a bad original cap or one that had an extremely high (+) tolerance.
