Table top solder blanket/tarp?
Started by Beedoola, April 01, 2020, 07:35:23 PM
Beedoola
Given the shelter in place, I can't really access my communal shop space where my work bench is.
My girlfriend is using my music desk for work and I want to build some stuff on the dining room table.
I wanted to get protective material to put over the table/my work area. Any suggestions? Doesn't have to be specifically for soldering but something durable enough. to handle if a drop of solder falls on there not to burn through to the table.
Thoughts/suggestions?
A couple layers of toilet paper and you should be good to go.  ;D
More seriously, you could use just about anything.  A towel would be pretty simple. Solder cools off very rapidly once the iron is no longer heating it.
I used the side of a cardboard box for years, no issues.  Now have something made from silicone.
Harbor Freight sells those tarps with felt backing.  Or even a moving blanket that would save the table from an errant dropped 1590B.
thesmokingman
#4
I bought a decorative Halloween themed cloth place mat years ago at Target had three skeletons dancing on it ... been my go-to for working on delicate surfaces ... if you want to get proper, an anti-static mat is less than $20 on Amazon
Piece of thin baltic birch plywood, masonite/hardboard/mdf.
Just grab some card board, you'll be fine.
MTK
I've been using that slip resistant shelf liner stuff.
https://i.imgur.com/nmLtBIc.jpg
Aentons
I use a couple of cloth placemats and some cardboard
brianq41369
I've been using the same thin ceramic floor tile (12"x12") with some rubber dots glued under the corners for 23 years?
I use a couple of these and they work great. I use a hot air station directly on it also with out burns/melting.
https://www.amazon.com/gp/product/B075SXRXTL/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Something i'll use even when working on my workbench is i'll work on a few old cookie sheets with 1/2" /1cm sides. That way if i need the bench space for something, my project, tools, paraphernalia are contained on the cookie sheet and i can quickly clear the space set it aside do what i need, put the cookie sheet back on the bench and carry on with that project.
Quote from: davent on April 13, 2020, 03:40:57 PM
This is a great idea! I may give this a try next time I Commandeer the kitchen table for temp building. I remember seeing some cheap cookie sheets at the 99 cent store by my house.
You could always graduate up to a sheet pan rack, reserving one of the pans as a workspace tray.
I have one, and it is one of the most useful tools I own.
Credit for the idea here:
https://www.madbeanpedals.com/forum/index.php?topic=29961.msg289598#msg289598
I need to purchase an additional sheet pan for mine.  I've filled up my "current project" pan with too many open projects.   :-[
MTK
Quote from: EBK on April 15, 2020, 06:36:23 PM
That's genius!!!
