Dirtbag
Started by dwstanford, November 23, 2011, 04:50:50 AM
I would bet that over would give you a slightly longer delay time.
Quote from: dwstanford on November 27, 2011, 09:25:31 PM
With the delay pot, the closest to 100k i have is a 97k and a 103k.  Is it better to be 3k over or under?
Probably wont be a noticeable difference but yes 103k would give you a slightly longer delay time, but is your 240pF cap exactly 240pF and your 5k6 resistor exactly 5k6? They all play a part in the delay time.
The only issue that could arise is whine at higher delay times but that probably wont happen.
Go for either!
dwstanford
I just noticed i didnt order a 27p cap for c2.  Doh!  Could i sub a 22p or 33p, or should i get one thats exactly  27p?
Quote from: dwstanford on November 28, 2011, 03:07:11 AM
Either would be fine.
dwstanford
Thanks.  I appreciate the help.  Im sure i'll have lots of other issues as we go along, so hopefully some of it can help someone else.
