Author Topic: Carbon Comp v. Carbon Film in Mangler  (Read 1000 times)
Chimo
  • Diode Destroyer
« on: May 21, 2020, 07:33:38 AM »
I have all but one of the values (100k) of carbon comp resistors I need to finish my Mangler project and am wondering if I can use a carbon film in that slot without changing too much or rendering the project useless. I can eventually swap out for a carbon comp when I have the need to place an order for other items, but as it stands I just can't justify paying shipping for a single part.
Any thoughts appreciated, thank you!
  • Global Moderator
  • Jimi Lee
« Reply #1 on: May 21, 2020, 07:36:44 AM »
Are you talking about resistors?
Carbon comp are 5% tolerance, metal file are 1%. If nothing else it’s closer to the correct value than than carbon.
benny_profane
Re: Carbon Comp v. Carbon Film in Mangler
« Reply #2 on: May 21, 2020, 07:55:40 AM »
Carbon comp resistors have varying levels of tolerance. Carbon film is usually 5% and metal film is usually 1%. Unless you’re going for a ‘mojo’ build and want it to look a certain way, there’s no reason to use carbon comp over any of the film varieties.
Chimo
  • Diode Destroyer
« Reply #3 on: May 21, 2020, 08:01:15 AM »
Thanks for the replies! Definitely just want a functioning pedal to play with. Looking forward to finishing the build!
benny_profane
« Reply #4 on: May 21, 2020, 08:35:55 AM »
Yeah, you’re fine with whatever variety given that the value is correct. Go forth and fuzz.
Aentons
  • but..but.. why?
« Reply #5 on: May 21, 2020, 10:03:38 AM »
From what I understand the carbon comp resistor "mojo" perception is mainly due to the fact that they are noisier at higher voltages which tube amps use, but pedals do not, so go with what you've got. The way I think of it is kinda like vinyl records, they are terrible at what they actually are supposed to do, but in a very specific pleasing way that we are used to. On the flip side, you could also think of it like an instagram filter on a photo, it destroys the original full quality.
WormBoy
  • Solder Ninja
  • TJ
« Reply #6 on: May 21, 2020, 10:17:55 AM »
... it destroys the original full quality.
Well, that's the whole purpose of a fuzz, ain't it?  8) That said, I don't expect that anybody can hear the difference between carbon comp, carbon film and metal film resistors in a fuzz face (at the same resistance value).
  • Aotearoa
    • http://alanp.info/
« Reply #7 on: May 21, 2020, 11:47:35 AM »
My understanding... carbon comp are 10%, carbon film are 5%, and metal film are 1%, in general, with noise decreasing in that order as well.
Your pedal is going to sound a lot closer to spec with 1% than 10%. YMMV in valve amps, of course.
  • Global Moderator
  • Jimi Lee
« Reply #8 on: May 21, 2020, 12:34:51 PM »
Yeah, you’re not going to be able to hear the difference, but you can feel the mojo.
Mich P
  • Solder Ninja
ahiddentableau
  • Solder Ninja
  • J
« Reply #10 on: May 24, 2020, 05:29:41 PM »
When I read the first message I was going to post a link to that RG Keen article but Mich beat me to it!
Love me some RG Keen articles.
