What I was thinking? - I was right! (Phantom power)
Started by SirEgno, May 28, 2020, 04:43:28 PM
SirEgno
some years ago I started to build a mic preamp with phantom power supply.
I bought a 2x15v transformer as main power and for the phantom a... 2x12v transformer.
What strange drugs did I take to get this idea? How can I get 48v from 2x12v transformer?
I bought also every component to build this project and there is no charge pump or something similar.
Only a 48v zener diode.
SirEgno
you're right!
my knowledge is regressing  :-\
Are there some advantages using a full bridge rectifier?
like this:
Doubling the voltage the current is halved, right? the transformer is 0,5VA (2x0,25). so the current should be about 20mA?
If i recall, peak voltage with a doubler is 2.8 times the secondary so i've gone with the ampere rating divided by the 2.8 factor. I've used the simple version in a number of tube amps for the high voltage rail, they've run with without issue for years. No idea whether the bridge may offer in improvements.
SirEgno
So, 24*2.8=67.2. That's why I also bought a 48v zener diode.
The schematic attached should be fine. But I think I have to add a resistor on the red circle. right?
Thank you very much for helping me!
Your welcome.
The resistor, i don't know but, there is this project for a phantom  48v supply from Rod Elliot that uses a voltage doubler, he has a small value resistor in each power line.
https://sound-au.com/project96.htm
