3pdt toggle switch
Started by Guybrush, June 17, 2020, 10:59:27 AM
Guybrush
Hi all
I'm looking to build a new test rig and would like to use a 3pdt toggle switch (rather than a footwitch). Unfortunately I can only find on- off on-on and on-off-on toggle switches. Does anyone know where I might find the necessary on-off version?
Thanks as always.
Quote from: Guybrush on June 17, 2020, 10:59:27 AM
Hi all
I'm looking to build a new test rig and would like to use a 3pdt toggle switch (rather than a footwitch). Unfortunately I can only find on- off and on-off-on toggle switches. Does anyone know where I might find the necessary on-off version?
Thanks as always.
Pretty sure this is what you are looking for. Underlined.
Guybrush
Oops, that's a typo  ::).
Will go back and edit. Thanks
On-on is the one you want.  Here, "on" just means each pole is connected to one of the throw terminals in each of the two switch positions, same as in the stomp switch.
Quote from: EBK on June 17, 2020, 01:54:39 PM
Yep, just your standard 3pdt toggle switch is what you want. It's wired the same way, that way, you have bypass and effected signal.
Guybrush
Ahh ok. Every day's a school day!
Thanks guys, much appreciated.
Given that it's a toggle, you can just use a DPDT. The extra pole in 3PDT stomps is needed to show whether the switch is on or off, as you cannot tell from just looking at a stomp alone. With a toggle, you can just look at it.
