Wavelord changes tempo when hitting the bypass *SOLVED*
Started by ferdinandstrat, July 11, 2020, 11:25:56 AM
ferdinandstrat
This one is a doozy, so turns out the Wavelord I built has an issue where if you tap in a fast setting and hit the bypass it changes the tempo to slow for some reason, same when you turn a pedal before it on or off
I must say that I use an optical bypass in this one and a built in Klon buffer
ferdinandstrat
OK this is weird, I changed the LFO ic and all the problems were solved
