madbeanpedals::forum
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
Home
Help
Login
Register
Etcher's Paradise
Projects Page
Discont'd PCBs
Facebook
Twitter
DIYSB
JMK
1776
THcustom
LECTRIC-FX
Grind Customs
smallbear
StompboxParts
BLMS
DIYGP
BYOC
Donut
Projects
Tech Help - Etcher's Paradise
Egodriver help...
« previous
next »
Print
Pages: [
1
Author
Topic: Egodriver help... (Read 392 times)
pgodfrin
Transistor Tickler
Egodriver help...
on:
December 05, 2020, 10:45:46 PM »
OK, got it etched and built. I have a signal on pin 3 of the TL082. I should have something out of pin 2 heading to gain, but I don't.
arrrrrrrrgh please help. Wh am i missing?
Logged
Administrator
Electron Doctor
Brian
Re: Egodriver help...
Reply #1 on:
December 06, 2020, 07:39:30 AM »
It's normal not to hear output from the inverted pin (pin2). But you should hear output at pin1. If not, then something is wrong with the IC, soldering or the board etching most likely. Also, you'll want to check for proper voltages.
Logged
pgodfrin
Transistor Tickler
Reply #2 on:
December 06, 2020, 08:43:02 AM »
OK, thats what I thought as the datasheet shows pin 1 as the output. I'll post the voltages later today.
One question about the voltages - how do I calculate what they should be? Is that simply Ohm's Law or is it something else?
Logged
Administrator
Electron Doctor
Brian
Reply #3 on:
December 06, 2020, 06:41:21 PM »
~9v on pin8
0v on pin4
~4.5v on everything else, although you may have a lower reading on pin3
Logged
pgodfrin
Transistor Tickler
Reply #4 on:
December 07, 2020, 07:17:07 AM »
Well, nuthin' doing. It won't work. I did find a tiny, teeny weeny piece of copper that caused a short to ground, but I still got nothing after fixing that. And between all the desoldering and scraping I totally macked up the board. So... I'm going to try again. Maybe this time I'll use the schematic to design my own version... I'll call it SuperEgo
. Now all we need is a pedal called Id!
Logged
Zerro
Diode Destroyer
Reply #5 on:
April 03, 2021, 09:05:03 AM »
Sorry, mistake...
Last Edit: April 07, 2021, 04:53:29 PM by Zerro
Logged
Print
Pages: [
1
« previous
next »
Projects
Egodriver help...
