greenbean2019 build - resistor issue
Started by redkurn, February 13, 2021, 01:19:49 AM
redkurn
So I ordered a 10M ohm from small-bear and on my Klein MM700 it's reading at around 6.5M ohm.
Resistor is supposed to be a 1%, but the reading is showing it far far under that spec, use or contact small-bear over it?
I've already soldered it in, but having second thoughts while I wait on the rest of the parts to arrive from tayda that small-bear didn't have or were out of.
danfrank
I don't see a 10M resistor on the GB2019 schematic. Are you referring to the 1M resistor at the input?
Yeah there is no 10M resistor on the GB. In what spot did you install it? Also, if you are measuring it in circuit that's probably why you got a low reading.
redkurn
Quote from: madbean on February 13, 2021, 04:59:47 AM
Quote from: danfrank on February 13, 2021, 03:39:24 AM
Sorry, was building the greenbean and had a brain fart.
They 10M was for VFE Triumvirate, it's not soldered in and was tested twice alone.
Close to the resistor reads about 6.5M.
I was wondering if this is normal or I caught a bad one before it destroyed my diodes. since I'm a diode destroyer 😂
That's the standard pulldown resistor for all the VFE builds. I wouldn't worry about the low reading in that case. 6M is plenty overkill for a pulldown anyway.
Does the resistor show the correct color code for 10M? Wonder if they just accidentally sent the wrong value.
Don't know what the meter is but could it be an issue with the meter, does it measure other known high value resistors correctly?
redkurn
Quote from: madbean on February 13, 2021, 08:47:21 AM
Then I won't stress over it, I'm still very new and appreciate your work and help, I can solder like a champ since I've always done repairs, but learning about the components finally. 😂
Quote from: davent on February 13, 2021, 09:08:07 AM
My MM reads up to 40M and has read a 2.2M and 1M accurately.
It's pretty sweet for sub $100 and is made for professionals, it's all my electrician brother would ever use.
It's no fluke, but I'd say it's on par as far as use goes and it's true RMS so I can get forward voltage readings.
redkurn
Would it be possible to get the madbean bean in psd?
I want to put it on my greenbean. ;D
