Current Lover 11.2011 version, How to Kill Dry Signal?
Started by Puguglybonehead, July 11, 2021, 06:14:11 PM
Puguglybonehead
I have an old Current Lover board (not exactly current anymore) that is still only partially completed. I figured this would be the year I finally get it done but I have a few things in mind. I was hoping to try doing some TZF experimenting with it, using the send & return pads. What is the easiest way, on this version of the board, to kill the dry signal? I know on the 2015 board it's just a matter of lifting R28. On the 2011 Current Lover board, am I lifting R25 to kill the dry signal?
Puguglybonehead
Nevermind. Got it sorted. (more searching the forum) R16 (on both versions) to lift the dry signal.
Zerro
R25 and R28 are somewhere in LFO section...? Best way how to kill dry signal is not to put something between send-return loop :@) Let it free as two independent jacks or stereo jack with no switch pads when not plugged.
In the chapter "FX loop wiring" in manual you can see both ways how to use it.
