Just looked at my notes and here are some things that worked for my last mudbunny build for bass after socketing a lot of components. Here's what really worked for me, and I did a ton of research. Some are Green Russian values already, but these are all the areas that I kept reading about and listened hard to component switches. Glad to share this a I had to compile it and put it together. But the muff I have is great. Really love it. Very versatile.
Tone:
R18: 22k
R19: 20k
Flatter mids
C13: 10n
C14: 10n
Coupling Caps:
C3: 220n
C4: 220n
C7: 220n
C15: 220n
C16: 220n
Tone caps:
C2 470p
C5 470p
C8: 470p
Clipping caps:
C6: 47n
C9: 47n
All pots B100K
Like I said, I didn't like the blend. If you have a good sounding circuit I don't think it's necessary, esp since you can always turn the fuzz way down and the vol up to get a quasi OD/boost sound, which is very useable for bass when you don't want full on fuzz. I played mine with a blend at first and just didn't think it necessary.
The Hoof mids knob is very good too, if you want to go that route. However, I think that building in flat mids is the way to go to have less fiddling. Kind of a set it and forget it thing.
Also, if you put the diodes on switches. Having all LED's gives you something closer to a Hoof/Fuzz sound. Open gives you more of an OD/BIG sound, silicon gives you a more traditional sound. Mix and match too.
