Author Topic: Lectric-FX Flintlock Flanger (A/DA Flanger)  (Read 1637 times)
benny_profane
  • Electron Doctor
    • View Profile
Re: Lectric-FX Flintlock Flanger (A/DA Flanger)
« Reply #15 on: November 18, 2021, 08:51:33 AM »
Make sure you can find those MN3204 chips first! They are very, very scarce right now  :(
Good call. Yeah that might be a prohibitive one. Do you have any sources you can vouch for?
  • Electron Doctor
  • Dinner at Dorsia? No problem...
    • View Profile
« Reply #16 on: November 18, 2021, 10:00:04 AM »
Unfortunately no. Everywhere I have gone before seems to have supplies dried up  :(
benny_profane
  • Electron Doctor
    • View Profile
« Reply #17 on: November 18, 2021, 10:32:47 AM »
Ah, that's a drag. I'll have to do some research before embarking on that one in that case.
harryklippton
  • Electron Doctor
  • Will
    • View Profile
« Reply #18 on: November 23, 2021, 10:58:20 AM »
This build report has convinced me I need to build this pedal
benny_profane
  • Electron Doctor
    • View Profile
« Reply #19 on: November 23, 2021, 01:52:46 PM »
You won't regret it!
danfrank
  • Solder Ninja
    • View Profile
« Reply #20 on: November 24, 2021, 11:42:24 AM »
Nice!
This project also works really well with the MN3004 BBD. Clock needs to be adjusted and the clock cap needs to be upped to 27-30pf to get the frequencies correct. 20-800kHz clock range, 40 to 1! You can go down to 17kHz for a slightly wider sweep but watch for noise on the low end of the sweep.
Oh yeah, the MN3004 is 14 pin and MN3007 is 8 pin, just chop the extra legs off the MN3004...
« Last Edit: November 24, 2021, 11:48:41 AM by danfrank »
