I need and eagle part, please.
Started by jimilee, January 17, 2022, 08:07:43 PM
I'm looking for a 2n6027 part for eagle. If you can point me in the right direction for making one, that would be great too. Laying out a hummingbird tremolo.
JTM100
SnapEDA has the part available...
https://www.snapeda.com/parts/2N6027G/ON%20Semiconductor/view-part/?ref=search&t=2n6027
The service is free and usually has the parts I need but you can also request parts to be created.
You will have to add it to your library.
Good luck!
El Jefe at Tex Mex Effects
Quote from: JTM100 on January 17, 2022, 08:19:28 PM
Good luck!
Hey, thank you. I used that, but the footprint board model was off, the pads were touching. How can I edit that?
JTM100
I don't have a lot of experience with this, so there's probably an easier way to do this.
You'll have to edit the package...
In the Control Panel window, click on File, then Open, then Library. Select the library that contains the part you want to edit.
This will open a new window. Select your Device (part) on the left, then double click on the associated Package (footprint) you want to edit. A new window opens with the footprint you selected. You can then move the pads where you want them. Click save and that should be it!
Not sure if you have to close and re-open Eagle to load the newly saved footprint.
Hope this helps!
Send me a message Jimi. I can help you out.
