Honeydripper with mods
Started by DGWVI, December 29, 2022, 10:57:17 AM
DGWVI
Stock it's a great circuit, though it does have its limitations which I've tried to mitigate with a handful of mods. There are some other things I'd like to try, but I want to wait until I can get my hands on a few more PCBs before experimenting any further, so I can compare and contrast.
So, the mods I've done are
R1 (100K) replaced with a 1M trimmer have it set for 1M in the vid. This is to increase input impedance, and while subtle I do enjoy it
R5- has been increased to 270k for more input gain
R6 has been increased from 4.7k to 270k to give it more zippiness (according to Mark Hammer, though he suggests 220k). Definitely gives it a little something extra
(Ignore)R9- has been replaced with a 250kB pot, I'm calling this balance, as it adjusts the amount of signal going into the lower tuned filter. Highly interactive with the sweep pot, also effects decay time a bit
R18 is 2.2k because that's what I grabbed
R44 (4.7k) has been added between pin 1 of the Sweep pot and ground to limit the signal dumped to ground and increase the usable range
Sweep pot has been changed to Anti-log taper from linear. Value remains 10k
C1 has been increased to 27n to allow more into the circuit
C2 has been decreased to 1n to raise the cutoff of the clipping circuit
D3 & D4 have been changed to BAT46 for a bit more sensitivity
IC1 is LM1458, though TL072 works great here as well
IC2 & IC3 are currently TL974, though I'm still experimenting with those. The 974 seems a bit dirtier than the 324
I'm really hoping this one makes it back to the shop, as it's a wonderful alternative in the world of envelope filters
Edit - Edit- I copy and pasted from my notes app, and didn't catch it. R9- is stock. R22 has been swapped for a pot to effect the gain of the first peak detector. Guess I'll need to relabel that pot
DGWVI
Meant to post this is the main build reports sub forum, could an admin please move it?
Quote from: DGWVI on December 29, 2022, 11:01:58 AM
OR you could post a demo of this awesome machine!
DGWVI
Quote from: jimilee on December 29, 2022, 11:33:38 AM
It's in the other thread ;D ;D
