2024 outlook
Started by madbean, January 23, 2024, 01:53:01 AM
Aentons
Quote from: madbean on February 09, 2024, 02:12:06 AM
Quote from: Aentons on February 09, 2024, 01:41:06 AM
Just curious if there is any reasoning behind designing the standard series exclusively for the 1590b rather than both it and 125b? Some folks seem a tad hung up on top jacks.
A number of the circuits I'm working on for the series simply won't fit in both configurations. Some would, for sure. But then they wouldn't be "standardized" for one pre-defined hardware layout. I've got a pretty big hunch that when folks start building some of these projects they'll find them easy and enjoyable. At least, I hope so because I put in a tremendous amount of thought and planning into them, haha.
I was just thinking, that if it fits into a 1590b, a 125b is bigger in every dimension, so what's to stop you from using the larger size? Sorry, if I'm being dense.
Quote from: Aentons on February 09, 2024, 03:36:10 AM
Not dense at all! 125B requires extra space at the top end to fit the jacks and you have to make compromises to offer both options for 125B and 1590B simultaneously in a single PCB layout.
Frankly, I already did that in 2020 with a bunch of projects and sometimes that required a mix of 16mm snd 9mm pots. I dont think thats the best approach anymore. This series is about focusing on a specific layout standard for 1590B with minimal wiring and different bypass options. And, also because I want to make it easy for people that want to use the Tayda drilling and UV print service at the same time. These weren't even options just a few years ago.
Micpoc
Quote from: madbean on February 09, 2024, 04:07:50 AM
Does this mean that all projects with, for example, two pots and a toggle switch (plus foot switch, jacks, etc.), will share the same drilling pattern? So if we build one and get tired of it or whatever, we can repurpose the enclosure without any modifications?
Aentons
That makes sense. I'm definitely excited to see it all in action once it's ready.
Quote from: Micpoc on February 09, 2024, 02:53:11 PM
No, because each project will have a unique number of controls. But they all go on a per-defined grid.
The idea here is to have one master template for the Tayda drill service so for any given project you can just adjust that layout to fit the specific number of controls needed. I'll be documenting this in depth so it will be easy for anyone to do. Also, because I am personally not wanting to do my own drilling too much anymore! I'd rather pay Tayda a few bucks to drill my enclosures than deal with going out to the garage and mis-drilling my own stuff haha.
There are a couple projects that do break the design rule a bit but those will have their own paper and Tayda drill files.
redkurn
TNblueshawk
Hey Brian, is the Collosalus coming back?
John
Quote from: TNblueshawk on February 18, 2024, 01:44:20 PM
Mos def. I will get more Collosalus and Current Lover on the next order. Just deciding if I want to fully update to my latest parts library. Probably will.
On another note: I am a debugging madman! Solved a big problem on one of the new projects today. Held me up for two days.
jessenator
Quote from: madbean on February 22, 2024, 12:17:50 AM
always a good feeling!
"All you need is fuzz"   ~not Lennon
pbrommer1
[/quote]
Brian, the big brain, am winning again. Now, he will release pcbs for no raisin!
Verified 7 builds as fully ready today. I found small errors on two other projects that will require re-running those boards. Not a big deal. Just a couple dumb mistakes on my part.
Starting to work on art for Tayda UV printing (first time). Here's the 8-Ball.
And, here's my build of the Woodshed fuzz which sounds absolutely awesome!
jessenator
Quote from: madbean on February 23, 2024, 12:41:29 AM
Micpoc
Well, THAT looks interesting...
Very cool.
playpunk
The 8ball is my favorite DIY drive ever.
"my legend grows" - playpunk
