runoffgrove mockman PCB?
Started by movinginslomo, July 10, 2024, 09:01:24 PM
movinginslomo
She's finally together boys, but she's passing a very weak signal.. any ideas where to start? I checked with multiple IC's (including verified legit new) so I don't think it is that
Quote from: movinginslomo on April 14, 2025, 04:11:02 PMShe's finally together boys, but she's passing a very weak signal.. any ideas where to start? I checked with multiple IC's (including verified legit new) so I don't think it is that
Voltages, clear closeup pics or front and back and a schematic. Reflow all your solder joints, check for bridges and reflow all your solder joints.
movinginslomo
reflowed and checked values. I did notice on zombiesnore's build doc it calls for a 47n output filter cap while on the runoffgroove site it calls for a 470pf cap. I am using a jrc4558 op amp. I am going to breadboard this circuit and see if I get the same result
zombiesonore
If there's a difference between my doc and runoffgroove's schematic then the mystake is on my side of course.
I'm not at home this week so I don't have access to my files for checking any mistake...
movinginslomo
Quote from: zombiesonore on April 18, 2025, 09:48:46 PMIf there's a difference between my doc and runoffgroove's schematic then the mystake is on my side of course.
when I get time I'm gonna try and breadboard the parts and see if it works as intended.
zombiesonore
Hi !
As I don't have access to my kicad files, I've downloaded my own pdf...
1) Why didn't I put my schematic on the pdf ? Why ? :-/
2) On my B.O.M. the output cap, parallel to the volume pot, is C7 and call for 330p to 680p (Cx on runoffgroove's schematic). So no mistake here. 470p is a good start.
3) Can you post photos of your build, maybe it's a simple wiring issue ?
zombiesonore
Footswitch wiring scheme is the same as the one found here https://www.madbeanpedals.com/projects/_folders/DistBoostOD/pdf/Deadringer2022.pdf (left switch of course.)
For the jacks, pads are left: GND, right: signal, components side.
movinginslomo
yes I used madbean switch wiring. I'll try and get some pics when I have some time
movinginslomo
life gets in the way. Pics or it didn't happen?
zombiesonore
Here's my schematic attached.
Main difference is that I put a 1N5817 diode instead of a 100 Ohm resistance.
Added a 100n capacitor for IC power filtering.
On your pictures I didn't see any wiring mistake so maybe just reflow everything and check for bridges ?
movinginslomo
ah thanks I'll breadboard at some point
movinginslomo
ok I breadboarded zombiesnore's schem.. still weak signal. Must be some user error on my end if this circuit is verified. I did learn how to transfer a schematic to breadboard.. so win anyway?
zombiesonore
Hello,
I've breadboarded my schematic this morning. It's working. I failed to ear a difference with the switch on or off but definitively not a weak signal, quite the opposite.
One thing, replace the 1N5817 diode with /or put a 100R resistance in series after it, it tame the background noise of the circuit.
movinginslomo
Quote from: zombiesonore on May 04, 2025, 03:46:11 PMHello,
do you mind sharing your breadboard layout? it would be hugely helpful to make sure I'm not getting something wrong on my end.
zombiesonore
If I could I wouldn't mind but I've removed the components from the breadboard a few hours after doing it.
I've never had a circuit working on breadboard on the first try.
For this one, on first try => nothing. Check => forget to connect the opamp to +9V...
Breadboarding needs to be 5x check. It is tedious but a simple circuit like this one is a good introduction.
Good luck.
