Glasshole without SSBP
Started by slowpogo, May 16, 2025, 04:50:28 AM
slowpogo
I ordered the Glasshole but didn't see that it's made to utilize the SSBP bypass board.
I'm guessing I can just manually wire my stomp switch for true bypass and use the Send/Return as Board In/Board Out.
But there is no bypass LED on the main board, so what is the "LED" connection point for by the stomp switch, is that just 9V?
Correct,you can use that pad to connect to a CLR and LED.
Quote from: slowpogo on May 16, 2025, 04:50:28 AMI ordered the Glasshole but didn't see that it's made to utilize the SSBP bypass board.
Is this what you wanted to know?
https://www.madbeanpedals.com/tutorials/downloads/MBP_FootswitchWiring.pdf
