Drill hole size for 5mm LED fresnel lenses?
Started by Bret608, February 13, 2012, 04:02:58 PM
Hi everyone,
Does anyone know what the proper drill hole size is for the 5mm LED lenses from Mouser? I'm going to have to order drilled enclosures from PPP until I have a drill press, and I'm guessing they'll need pretty specific measurements to accomodate special requests like this.
Thanks!
Bret
Haberdasher
Are you talking about those vcc lenses?  I have some here, but my calipers are AWOL.  I do have a 1/4" hole drilled in an unused enclosure though, and I just dry-fitted one in there.  I think it might go if I pushed it, but it's awfully tight. I think 9/32 would be better?
Or get a $10 set of step bits from harbor freight and drill that one hole yourself with a handheld drill...
FABBED PCB's FOR SALE:
Now carrying Matched JFETS
Strategy
my trick for this is to drill a 1/4" hole and then slightly file/grind the edges of the hole with my dremel tool - one of the narrow grinding cones. I haven't found exactly the right size bit for this yet..
Strategy
Quote from: Haberdasher on February 13, 2012, 05:19:48 PM
Haberdasher
Ah- good to know that, strategy.  So would you say 9/32 is too big?
Thanks guys! I am definitely curious about the 9/32"--I do have a decent hand drill and a Harbor Freight close by, so I could go that route.
