Author Topic: No battery snap & switch wiring question  (Read 5402 times)
theviper21
  • Diode Destroyer
« on: March 22, 2012, 07:53:52 AM »
If I want to omit the battery snap and just use the D/C adapter, do I just run a wire from the input ring to the dc jack or do I just forget the wires between the snap and the swith/dc jack?
Also, for the 3PDT footswitch, there are three different places you connect the ground. For the actual wiring, is it best to just run small jumper wires between the three connections? I haven't been able to find any up close pictures of what it's supposed to actually look like.
Thanks!!
« Last Edit: March 22, 2012, 07:56:04 AM by theviper21 »
sgmezei
  • Scott- AB, Canada
Re: No battery snap & switch wiring question
« Reply #1 on: March 22, 2012, 08:59:02 AM »
Just leave the battery snap unconnected at both connections. Thats it! easy hey?
Now for the stomp switch. I use a leftover resistor lead that has been snipped to connect those three ground points but you can most certainly use a a bare wire. In fact, thats how I started doing it.
theviper21
  • Diode Destroyer
« Reply #2 on: March 22, 2012, 11:24:34 AM »
Brilliant idea on the switch, wish I would have saved my clipped leads!
TNblueshawk
« Reply #3 on: March 27, 2012, 02:54:47 PM »
Viper, thought I'd add if using the stereo input jack you never put anything on the ring lug. Also, since you are not using a battery you actually don't need to use a stereo input jack, you can use a mono there as well, like your output jack.
John
