LED Orientation for Boneyard
Started by dfine22, April 28, 2012, 08:04:15 PM
dfine22
I want to get the orientation of the LED's on the boneyard correct and I forget. Square pad (+)?
pryde
Yes. Square = +
Also for reference, look at your electrolytic caps on the pcb. the square pad is labelled with a "+"
dfine22
armkon
Hey i don't want to make a new toppic, so... About same effect Boneyard:
With what voltage running this effect 9V or 18V because the tc1044 is charge pump??
If it's working with 9V, the 18V will not be better for him, because i miss a point and need a little explanation, sorry :)
stecykmi
the TC1044 is used to generate a -9V supply. It doesn't generate a +18V supply.
armkon
but same preamp power up with 15 -15 or 18 -18 will sound better? i have heard opinion that 9V version got less mids and play differen then even 12V version
If you go for +/- 15V, I suspect your components will need to be rated at least 35V, since there will be a 30V difference. I could be talking out my ass.
