Drill template for Zombii for "B" size box
Started by Beedoola, July 08, 2012, 09:30:38 PM
Beedoola
anyone happen to have a drill template for a Small Bear "B" "z vex" sized box? Thanks.
Haberdasher
Here's one that someone posted a long time ago.  If it is the one I'm thinking of it should be printed at 300dpi.
I should add that I haven't used this and can't vouch that it's a lock.  Also note that this is probably meant for 9mm pots and likely wouldn't work for 16mm ones.
FABBED PCB's FOR SALE:
Now carrying Matched JFETS
Beedoola
thanks el duderino! I actually ordered the 9mm pots from Smalll Bear so it should be a go. I'll print it out and see if it lines up with the enclosure when it gets there. Thanks again!
