an easier flanger?
Started by eniacmike, November 22, 2010, 03:05:19 AM
eniacmike
I saw a band last night and the guitar player was using the maxon fl-9 and it sounded awesome.
I looked at a couple of projects over on tonepad and they look really complex. I heard the electric mistress is really hard to do too, is there any way to make an easier flanger? I might just buy the ehx nano mistress but I heard they aren't as good as the older ones.
Probably because it's not analog. By nature, analog Flangers are big and complex and expensive. Even worse is the uber cool a/da flanger.
I've built the fl301 project at tonepad. It's awesome, but it's a 1590bb project at least.
Easier or smaller? Not seen one yet.
I got my FL301 in a 125B...fits okay. Little tight, but even managed to get are charge pump in there too to run it at 15v.
Anyway, I think there might be a simple flanger on John Hollis page. Yep, the Ultra Flanger: http://www.hollis.co.uk/john/circuits.html
Haven't built it, but I'm sure there is some info about it on DIYSB.
eniacmike
okay well then a madbean flanger then. with onboard charge pump (if needed) and a tight design.
I am not so worried about the size of the pedal, but the bom's for the flangers I have seen make my head spin.
I will look to see if there is a layout for the ultra flanger.
I wonder about Flangers a little bit. I think I wanna look into the Electric Mistress, but the expectation of the potential rarity of the chips is turning me off a little. I hesitate, and I don't even know if they're readily available even! In any case, the boards don't seem to be readily available. Probably have to go and pick up a good old big box EHX mistress if I want to try it out.
Over at DIYSB, solderman posted a cool project based on the Guyatone flanger, which uses a MN3207/MN3102 pair. I think it sounds great. I'd actually like to see that one done up as a madbean project, because I don't care for solderman's all-in-one layout (it has the 3pdt pads on the board).
johnk
#6
i built the madbean current lover and it just barely fit in a 125B. it does sound great though.
....and I got my Tonepad F-301 including a charge pump in a 1590B with no problems. it was a fairly tight fit but not too difficult.
johnk
thanks guys. I prefer the sound of the Current Lover over the F-301 by quite a large margin.
Guitarmageddon
Did someone say "easier flanger?"  ;)
Spud knows tone!
Captain Cod at
www.codtone.com
kothoma
Quote from: madbean on November 22, 2010, 06:31:36 AM
Quote from: eniacmike on November 22, 2010, 06:35:26 AM
Just be aware that a lot of people report ticking problems with the ultra flanger.
See for example here: http://archive.ampage.org/threads/6/open/341507/John_Hollis_Ultra_Flanger-1.html
and several threads at diystompboxes.
