Lil' Green Watter!
Started by nzCdog, November 03, 2012, 11:23:26 PM
jeffaroo
have any boards?
i think im going to do it    :o
Not enough germaniums in this world to complete my wish list !
jeffaroo
Maybe talk to Haberdasher about etching you one... or ask around, there's bound to be someone else who can do a board for you. :)
I may do a fabbed board at a later stage if there's enough interest
BRGPollen
I'd Be interested in a fabbed board!!!!
"B"
The Musician's Theory of Relativity . . . . . E=Fb
jeffaroo
and the tube / tube socket has arrived ! ! !    ;D
BTW i got a decent ribbon cable from mouser
jeffaroo
Im in the middle of building the Watter, C2 & C4 call for 27n all that Mammoth had was .022uf
will this work, or should i get the right ones from mouser?
Oh btw, im gonna get the MOD 8" for this bad-doggie !    ;D
Woo!  You can use 22n or 33n, but it will sound slightly different... I tried lots of different values when designing it.  You could use 22n in parallel with 4n7 to get approximately 27n if you prefer... :)
gtangas
#37
hi
It´s possible to add bass and treble?
on the video that you post and after the rangemaster you are using a OD klone.
What was it?
Thx
Well feel free to experiement!  There is a bright/fat switch in the design which alters the frequency response, as well as some suggestions for Cap subsitutes in the build doc ...
The pedals in the video were a HBE Germania, and Madbean Sunking :)
fendman
#39
Hi , Have enjoyed following this build and the end product looks and sounds great.
I was wondering if it would be possible to power this project with a RoadRage???
I just realised the RoadRage would not be able to deliver 200ma  duh!!!  Anyway it will still stay on the wish list :)
Quote from: fendman on January 05, 2013, 03:47:17 PM
Thanks! :)
QuoteI was wondering if it would be possible to power this project with a RoadRage???
No... the tube heater draws too much current for the roadrage.  For this project you need a regulated 12VDC power supply capable of at least 250mA depending on the tube you use.
rutabaga bob
Learned about this through a post on DIYstompboxes...will definitely check it out!  THANKS!  Larry
Legalize Shemp!
jeffaroo
Welcome to mad bean !
i think it was me that sent you here     ;D
Vallhagen
#43
...finnishing my lil watter up here... causing a bump on this thread:)
Foolproof question (statement?): There isnt any black magic going on, right? So: I dont need to connect pin 9 from the tube socket to the board.
Another thought, even though i think we play safe: As we are dealing with pretty much more power (and current; 1W in 4Ohms means 0.5A) here, than in "the average stompbox", did you calculate the correct pcb trace width concerning this?
Well... ill be back pretty soon with the finnished build:)
Cheers
*** EDIT: Hmm, my intention was to write this post in the "member projects... Lil Watter thread", and i guess i was doublereading while posting... Well, here it is anyway :)
Quote from: midwayfair on November 04, 2012, 05:30:06 AM
Quote from: nzCdog on November 03, 2012, 11:23:26 PM
If anyone is interested I'll put together a project sheet with the schematic and pcb artwork at some stage.  :)
Um, heck yes? This is something I've been thinking of for a while (combining the tube pre with the 386).
You got two excellent sounds for such a simple amp in that video: The rangemaster (LM386 amps tend to sound dark) and the Les Paul + reverb with the amp dimed. I don't think it handled the Klon as well, though.
Agreed.. I would love to see this also.
