Question about Madbean's Shared Eagle Library
Started by aziltz, December 13, 2012, 03:13:33 PM
aziltz
Brian, or someone in the know, maybe you could tell me.
The enclosure outlines in the shared library I got from circuit workshop, is that the outline of the enclosure walls, or the outline of a board that would definitely fit inside of said enclosure?
Working on some stuff with mounted jacks so I need to get it right.  thanks!
I think it's pretty close but I usually just print out the board to scale and measure it up inside said enclosure.
Josh
aziltz
#2
ah, good call.  i'll try that.  I'm putting neutrik jacks on board for a 125B, but there on 3 sides, I want to get it right the first time.
edit:  well it fits, but Its hard to tell if the jacks in the layout will be in the right place.  I guess if someone has used these jacks before in a 125B they could tell me how far apart they should be spaced?
http://www.pedalpartsplus.com/mm5/merchant.mvc?Screen=PROD&Store_Code=PPP&Product_Code=6013&Category_Code=JAC
