Got my mouser shipment today, so I'm going to try to put in some more parts.
I'm planning on running MN3005s at 15V, so after reviewing the updated doc, here is what I think I need to do next.
R13 and R14, need to be removed and socketed(I put 10K in there since there was no * on the parts list), notes show 33-47k for running at 15V I think I'll start at 47K and see if there is any distortion
R27, 55, and 58 get jumpers
I also need to remove D1, along with a jumpered R58
D2 stays empty according to note on power supplies, however it does not say it should be jumpered.
Looking at the schematic, I think this is correct, 9-15vDC connects through D3 a 1N914,and two resistors of 22, and 100R, so 122R. Pretty much the full 15V to the BBDs
R56, already socketed, I'll start with 470K
I also attached wires for the switch and the ghost mod.
I build my road rage as well, note from the side view the regulator is not touching the board. I've seen regulators bolted down to boards to work like a heat sink but this board has pads for a pot that I'm not using, so Idont want it to make contact to the board.
I'm not putting in the 3005s or the 3101 till everything is done, should have my small bear order with vactrol and pots tomorrow. Brian was kind enough to send me a !M trimmer, cause I could not find one.
Getting pretty close.
