General wiring diagrams
Started by madbean, December 01, 2010, 04:27:21 PM
knd
Thank you mister!  What I was fuzzy about was the stomp switch wiring!
Quote from: bigmufffuzzwizz on July 18, 2011, 04:03:47 PM
Quote from: knd on July 18, 2011, 03:33:08 PM
Hi Brian,
Do you have a wiring diagram for two stuffing two effects in one enclosure using the same 9V source?
How is the output of effect #1 connected to input of effect #2?
Instead of output of effect 1 going to the tip of the out jack it goes right into effect 2 in.
http://www.google.com/search?q=PUT+2+FX+IN+ONE+BOX+
Matt Gnarly
Is there any chance of these diagrams getting re-uploaded? I'm trying to figure out how to wire up a project without a battery snap (do I just omit the third terminal?) and if I can use mono jacks for both input and output (as the lack of snap would negate the need to ground it to the tip terminal). Any help would be greatly appreciated!
enjoyadrian
second for getting the wiring diagrams reupped.
bigmufffuzzwizz
Quote from: Boxcar on February 09, 2012, 09:11:58 AM
The main wiring diagram is still up, its in the top right corner of the projects page. If you wish to build without a battery you CAN use 2 mono jacks since you don't need the ring lug anymore.
http://www.madbeanpedals.com/tutorials/downloads/StandardWiring_MBP.pdf
ecelec
 Love the new wiring diagram! good job!
